Alt 06.10.2004, 20:52   #1
RSV1000R
a
RSV1000R befindet sich auf einem aufstrebenden Ast
Technische Daten de 05´Mille
Glaube das das die Daten der 05´Mille sind, leider in Englisch, aber das ist ja kein Problem hoffe ich! :-)
Fuel:
95 RON unleaded petrol
Bore and stroke:
97 x 67.5 mm
Displacement:
997.62 cc
Compression ratio:
11.8 : 1
Maximum power at crank:
138.72 hp (102 kW) at 9500 rpm
Maximum torque at crank:
10.9 kgm (107 Nm) at 7,500 rpm
Fuel system:
Integrated electronic engine management system. Indirect multipoint electronic injection. Throttle body diameter: 57 mm.
10,3 litre airbox, with Air Runner air scoop.
Ignition:
Digital electronic ignition, with one spark plug per cylinder and integrated injection
Starter:
Electric
Exhaust:
Double silencer with three-way catalytic converter and lambda sensor (Euro 2)
Alternator:
12V - 500 W
Lubrication:
Dry sump with separate oil tank.
Double trochoidal pump with oil cooling radiator.
Steel oil tank
Gearbox:
six speed with ratios:
1st 34/15 (2.27)
2nd 31/19 (1.63)
3rd 26/20 (1.3)
4th 24/22 (1.091)
5th 24/25 (0.96)
6th 23/26 (0.88)
Clutch:
Multiple disc wet clutch with patented PPC power-assisted hydraulic control Braided metal clutch line Radial pump with 15 mm piston.
Primary drive:
Straight cut gears with ratio: 60/31 (1.935)
Final drive:
Chain
Ratio:
40/16 (2.5)
Frame:
Box section sloping twin-spar frame in aluminium alloy.
Front suspension:
43 mm Showa upside-down fork, with adjustable compression, rebound and preload. 120 mm wheel travel.
Rear suspension:
Aluminium alloy double member swingarm. Aprilia Progressive System (APS) linkages. Sachs monoshock with adjustable compression, rebound, preload and length. 133 mm wheel travel.
Brakes:
Front: Brembo double stainless steel floating disk,  320 mm. Radial callipers with four 34 mm pistons and four sintered pads. Metal braided brake line.
Rear: Brembo stainless steel disk, Ø 220 mm. Twin 32 mm piston calliper. Sintered pads. Metal braided brake line.
Wheels:
Forged aluminium alloy
Front: 3.50 X 17"
Rear: 6.00 X 17"
Tyres:
Tubeless radial;
front: 120/70 ZR 17
rear: 190/50 ZR 17 (alternative: 180/55 ZR 17)
Size:
Overall length: 2035 mm
Overall width: 730 mm (at handlebars)
Overall height: 1145 mm (at windscreen)
Saddle height: 810 mm
Handlebar height 830 mm (at bar ends)
Wheelbase 1418 mm
Trail 101.7 mm
Steering angle 24.80°
Dry weight:
189 Kg
Tank:
18 litre capacity (including 4 litre reserve)
Colours available:
Aprilia Black, Fluo Red, Mirror Silver
Mfg. RSV1000R
RSV1000R ist offline
Alle Zeitangaben in WEZ +2. Es ist jetzt 20:08 Uhr.
